I had a question about the DVDFab 9 BD ripper.
I was thinking of installing a second optical disk. Is it possible to queue the rips so that they're done sequentially after the "start" button is pressed?
I've read that it's possible to run multiple instances of DVDFab, but it suits me better if I were to be able to run one instance and it have it do the rips one at a time.
The conops would be something like:
1. insert disc 1 in drive 1
2. insert disc 2 in drive 2
3. select what to rip from drive 1
4. select what to rip from drive 2
5. adjust advanced settings (I would imagine it would apply to both rips)
6. start the rip
Is this possible or is the only way to do this to run 2 instances of DVDFab at the same time?
Thanks.
6. start the rip
Thanks.
