Command Line /VOLUME
    Hi, I can't get the /VOLUME switch to name a folder in a DVD rip. This used to work in version 8.
    What I get now is whatever the disc volume name actually is. The one I'm doing just now outputs to a folder called 'G7_70734D2' instead of 'Bates Motel Disc 2' which I enter in my command line.
    Currently on Version 9.1.2.8.
    Any ideas? Thanks.
    Cheers.
    We will fix the issue ASAP.
      Ah super thanks!
        Please update to the latest version V9137.
        The issue is fixed.
