BluFab 9135 loses my keys
    License/Key BluFab 9135 loses my keys
    I installed this using Live Update. When I restart the program it says all my products are trial versions. On the website if I log in as a member it says they never expire. Downloading the key "key.dvdfab6" doesn't do anything.
    What's the solution?
    Downloading the keys will not work as the key files are for dvdfab 8, just re-activate blufab with your email and password should do it.
