Does the new merge feature work with 3d?
    New: Added support to merge files in DVD Ripper, Blu-ray Ripper and Video Converter.
    Does this work with 3d movies?
    Can it be used to merge ssif files when their are more than 1 set for a movie?
    When used with a 2 part movie (2 disks) does it merge into 1 non stop movie or just parts 1 & 2 on same disk like img burn does?
    The merge function just work in Ripper and Converter. And support to merge the titles in one disc only.
      QUOTE (And support to merge the titles in one disc only.)
      Can you give example when one would want use this function?
        e.g. The season disc and the videos that record by device.
          Ok thanks Wilson I understand it now.
