My DVD Fab will not boot up
    Guys i am having weird problem. My DVD Fab is hanging when you click on it. The only thing I see is the splash screen and it saying connecting to servers and then it becomes non-responsive. This has never happened before so what is going on. Thanks for the help.
    Hi Coop
    Please post your internal log.
    Also what is your OS (operating system)?
    CBR929
      I am running Win 7. How do you get internal log?
        Hi Coop
        Open Fab see pic, then use copy and paste in notepad save it, then use the attachment button to upload it to your post.
        CBR929
          That is the problem. FAB will not open. When I click on the shortcut the splash screen with the monkey comes up and that is where it hangs.
            Hi Coop
            You can also find them in your documents folder, DVD Fab9, log, DVD Fab internal.
            CBR929
              Thanks that helped. Here is my log for today.
              DVDFab 9.1.4.2 (2014/05/11 10:12:25)
              0m 00.09s: Init Public log : enabled.
              0m 00.09s: Init Private log : finish.
              0m 00.09s: App info: 2014-4-29
              0m 00.09s: App info: 9.1.4.2 9142 Official
              0m 00.14s: Init CrashReportSettings : enabled.
              0m 00.14s: Init DVDInfo_Log : enabled.
              0m 00.14s: Init Qt_Log : disabled.
              0m 00.65s: Profile Manager :: Begin Load Profile
              0m 00.73s: Qt Translator file load success
              0m 00.73s: App info: client type 2.
              0m 00.74s: Fabplay load: preload successful.
              0m 00.84s: Fabplay load: Load successful.
              0m 00.84s: Init process: Transfer settings successful.
              0m 00.84s: info: fabcheck logpath= C:/Users/Brad/Documents/DVDFab9/Log/
              0m 00.93s: fab_check_gpu is running ...
              0m 09.99s: Profile Manager :: End Load Profile
              0m 10.95s: fab_check_gpu run out of time , terminating
              0m 10.95s: fab_check_gpu run successful
              0m 10.99s: info: recommand= 0, Shrink support= 0, enable= 0, cuda_cap= 0 , cpu_count= 4
              0m 10.99s: GPU check: GPUAccelerate-0
              0m 10.99s: GPU check: GPUAccelerate setting-0, 0
              0m 10.99s: GPU check: CUDA cap-0
              0m 10.99s: GPU check: Support coreavc decode-0
              0m 10.99s: GPU check: Lighting shrink status-0, 0
              0m 10.99s: GPU check: Graphics info 1: AMD Radeon(TM) HD 6520G : :
              0m 11.01s: Init process: Load config successful.
              0m 11.01s: Init process: Windows os type is 64bit System Windows 7.
              0m 11.02s: Init process: command line in is
              0m 14.13s: Reg check: Parse string: ( 1:0 )( OV:9142 )( BV:9143 )
              0m 15.10s: Reg check: Option check status-Reduce one time.
              0m 15.11s: Reg check: Option check status-Local
              0m 15.11s: Reg check: ( HD Decrypter:1:0 )-( DVD to DVD (Gold):0:0 )-( DVD to DVD:1:0 )-( DVD to Mobile:1:0 )-( Blu-ray to Blu-ray:1:0 )-( Blu-ray to Mobile:1:0 )-( File to Mobile:1:0 )-( Blu-ray to DVD:1:0 )-( File to DVD:1:0 )-( File to Blu-ray:1:0 )-( File Mover:1:0 )-( Blu-ray to 3D:1:0 )-( 2D to 3D:1:0 )-( Blu-ray Decrypt:1:0 )-( DVD Decrypt:1:0 )-
              0m 15.11s: App info: language type ENU.
              0m 15.11s: Reg check: Start get sys number.
              0m 15.13s: Reg check: Serial number is: 2e-b7-0d-49-8e-54:9c-b7-0d-49-c6-1c:9c-b7-0d-49-8e-54:a0-b3-cc-6e-97-e0
              0m 15.13s: Reg check: Connect type is: 1
              0m 15.41s: Init process: Init GPU settings successful.
              0m 15.84s: Reg check: Times of connecting error is: 0
              0m 15.84s: Reg check: Parse string: ( BV:9143
              0m 15.84s: Reg check: Option check status-NewWork
              0m 16.41s: Init preview: Begin init preview play engine.
              0m 16.41s: Init preview: Begin init preview play engine(XBMC).
                Hi Coop
                What anti virus do you have installed, if Bitdefender it's known to cause problems with Fab?
                Please uninstall version 9142 with Fabs uninstaller, download CCleaner found here http://www.filehippo.com/download_ccleaner/, run the registry cleaner with the option "old prefetch" checked in advanced options until nothing is found.
                Now download version 9143 found here http://www.dvdfab.cn/mlink/download.php?g=DVDFAB9_BETA
                save it to your download folder, right click the installer and choose install as administrator.
                Also make sure that nothing is preventing Fab from connecting to the internet.
                Let us know if still having problems
                CBR929
                  That did not work. It is still hanging requesting access to server on the splash screen.
                  I do not have anti-virus installed at this time.
                    You really shouldn't be on the internet without any anti virus you can at least turn on windows defender it comes with windows.
                    Check your registration in Fab see what programs are licensed.see screen shot.
                      @ Coop
                      I agree with my friend, you should have an anti virus software, even if it's the free versions, I use the free Avast.
                      @ glenns
                      That's the problem, Fab will not open to check.
                      CBR929
                        Retry 9143 again maybe the server went down for maintenance if no go try version 8 of fab just to see if it's a version 9 problem.
                          I know I should have anti-virus but I uninstalled it to see if that was the problem.
                          I thought Fab 8 was no longer supported. Is it on their site somewhere?
                            Fab 8 gets updates from time to time it should tell you if it's a version 9 problem if it works and version 9 doesn't.Can't hurt to try it.
                              I tried it and it didnt boot up either. Heck the monkey splash screen didnt come up on Fab 8. Does Fab need Microsoft Net-Framework?
