General Settings
    General Settings
    In DVDFab v9.1.4.5 - I can no longer find the place to make the 25GB disc the DEFAULT size for Blu-ray backups. Where did it go?
    Put a movie in the program then the pull down box appears with the settings for 50 gigs the default setting but if you change it to 25 gigs Fab remembers the last setting and will return to it.Theirs a newer version of Fab out also 9146.
