Keeping Menus when using DVD Copy
    When I am backing up a DVD, the latest version of DVDFab that I am using (9.1.4.5) has "Remove menus, play the titles continually" with a check mark next to it and it is greyed out.
    I can not find any way to uncheck that box. I want the menus. Is this a "bug" or can someone explain to me how to uncheck that box when it is already greyed out?
    Thank you.
    Craig
    Use Full Disk, not Main Movie.
      Thank you.... that solved the problem!
