Everytime I try to copy a 3D disc I end up with a 2D version. Can someone tell me the steps to get a 3D output. I'm writing the file to a media PC.
Thanks
Three ways:
1. BD Copy Clone: You could clone the disc to ISO or the blank disc, the result should be same with the source. 1:1
2. Fulldisc: You could compress bd50 the bd25 ISO/folder or blank disc. You need to select “Copy as 3D" option in Advanced settings.
3. Mainmovie: You could compress bd50 to bd25 ISO/ Folder or blank disc. You need to select “Copy as 3D" option in Advanced settings.
And DVDFab burning engine is needed when output to ISO or blank disc.
To playback the output folder, you need mount the .miniso file by DVDFab virtual drive and then play it in PowerDVD and TMT.
