v9.1.6.8
    v9.1.6.8
    when I try to install my antivirus block it from install
    anyone read in to this
    my antivirus is Avast
    Hi dholm26287
    Just installed 9168 no problem here, using Avast also.
    Try right clicking the installer and select run as administrator.
    CBR929
      I also got the same error, also using avast.
      (edit) I used the upgrade method from dvdfab instead of the full install. Could that be it?
      Mark
      Last edited by maonstad; 09-13-2014, 04:19 PM. Reason: Upgrading instead of full install
        Download it to your computer, right click and install as administrator. Mine went without a hitch.
