DVDFAB-File to DVD-Possible?
    Hi all,
    Can any one help?
    I want to know if DVDFAB is able to convert AVI or any video Codec to DVD. Which can be played on any home DVD players.
    If yes, can you advice how on earth can I do it.
    Your help is greatly appreciated.
    Thank you
    Kanee
    Fab can't do that yet but search the feature request and add a vote if thats something you would like to see.
      No it cannot.
      Fab IS NOT a DVD authoring package which is what you would need to do this.
        While DVDFab can't author an actual DVD, you can check the specs of your DVD players and see if they can play any media formats. Many DVDs are able to take a movie (for example, a DIVX file) or pictures stored on a DVD-R or CD-R (or via a USB port) as long as they're in the right format. It may take some experimentation to get the codecs and file structure right and it may not work the same on all your players, but it's a start.
