how much does the lifetime subscription cost and can i put it on both my desktop and laptop for one price or do i have to purchase it for both my machines?
thanks for any response
Go to DVDFab.com and check the prices for lifetime. You can have it installed on more than one computer but can only run one at a time while connected to the internet or you risk having your key blacklisted.
You can have it installed on more than one computer but can only use it on one single computer at any given time. As for the cost well that depends on the options you want to get and to find out go to this link here http://www.dvdfab.net/order.htm I also attached a zipped screenshot of the same web page with the costs of each option as well for lifetime
