I have recently started to have an issue with the DVD Copy feature.
My procedure:
This has stared to happen to about half the DVD movies I try to copy. In this instance the movies that failed were - St Vincent, and The Boxtrolls, etc.
Does anyone have an ideas why this is happening.
Thanks in advance
Phill
Windows 8.1
DVDFab v9 (w/DVD Copy & Ripper Activated) v9.1.8.8
Phillips Dual Layer DVD+R DL disks (as targets)
Dell Laptop XPS w/non BD DVD burner (factory DVD burner)
My procedure:
- Insert DVD (movie)
- DVD recognized
- press start
- Process completes without error
- I insert blank DS DVD
- Process completes with a SUCCESS
- I press Close
- I press Finalize
- I insert disk again to check
- NOTHING - the disk is blank
- If I open File Manager and click on the drive it asks if I want to use it like a stick or CD/DVD
- I eject the disk and visually inspect it - data was written to the disk
Thanks in advance
Phill
Windows 8.1
