Blue Lagoon is one of those discs whereby it detects that it is a copy and uses a playlist that gives scrambled M2TS order.
After doing some searching on the net, I've determined that playlist 692 is the correct one. I know that I can create a movie only version, which DVDFab detects that 692 is the correct playlist.
When doing a 50->25 backup, how do I get DVDFab to force the use of the correct playlist?
Or, is it possible to just rename the bad and good playlists by swapping their names? If that is possible, how does one determine which playlist is being used in the Blu-ray player?
I suspect that I am SOL and just need to use the movie only backup.
