Coding HEVC with GTX 980 GPU
    CPU/GPU Coding HEVC with GTX 980 GPU
    Hello, DVDFab is he going to use the ability to code via Nvidia hardware HEVC movies? THank for answer...
    Are you talking about for mkv's? In that case, I believe it is already incorporated?
    On the mkv screen there is a 4k/ h.265/ hevc option, and cuda is an option in the common settings screen.
