I just spent 40 bucks on a bundle of DL disks, burned one and found out my DVD player doesn't play DVDr rl disks.
DL DVDs will not play
Originally posted by The Phantom View PostI just spent 40 bucks on a bundle of DL disks, burned one and found out my DVD player doesn't play DVDr rl disks.
Then you gotta have one LARGE pile of store-boughts that you can't play, if that's the case...(most commercial releases - store boughts - are on D/L discs)...
DC
The default Log File location: C:\Documents and Settings\"User Acct"\My Documents\DVDFab\Log
The disks are Memorex DVD+R DL. I thought it was strange too given that most store bought DVD's are 8.5. I just thought it rejected them because it's an early DVD Recorder and couldn't read them. The disks do play on my friends 30 dollar cheapie player.
I'll try burning one as Rom and see what happens, hopefully it will work.
Originally posted by The Phantom View PostThe disks are Memorex DVD+R DL
Memorex DL's are not worth the hassles you are having, get some quality discs as I mentioned in earlier post !!
PS: They don't last either, even if you get a good burn, don't expect the disks to last !!Last edited by AlienX69; 01-13-2010, 05:48 PM.AX
