I'd like to script the command line to rip a set of BluRay disc images. I'm fine with the default MKV profile but I'd like to select the equivalent of the "High Quality" setting via the command-line. I've tried saving that as a new profile and selecting that profile using the command line but that seems to default to a fixed bitrate which isn't correct if the resolution changes. Any help would be appreciated...
Command-line option for High Quality?
