American horror season 3
    Hello folks can anyone tell me when I will be able to copy American Horror Story Season 3, Coven as yet I am not able to copy it. Thanks
    more info is needed, is this a dvd disc or a bluray disc
    please post dvdfabs complete internal log files.
      Hello comrade sorry for my ignorance not explaining myself properly please forgive me. I appreciate any help you can thus give and look forward to your reply please read my below brief with the information you have asked for provided below..
      American horror Story season 3 disc 1 is a Blu Ray I am currently re running the blu ray as we speak here is a screen shot of the failed disc copy as the blu ray time just creeps up and up from 2 hr. 2 minutes to like 1 hrs. and 30 minutes and then DVDFAB just hangs it seems to stick at around the 17% mark and this is the only disc it does it with and dvdfab copy's everything else. I never have this problem with anything else.
      The log file confirms no problems as the scree shot picture proves dvdfab says abort process.
      Picture 1 is the start of recording. Note the time on picture 2 compared to picture 3
      4m 42.68s: DriveX msg: adding media in driveX J.
      4m 42.69s: Source managerpen source flag:1,1,1,1,1
      4m 55.30s: opening drive J
      5m 07.12s: opened i/o
      5m 07.13s: got media type 15
      5m 07.69s: got max lba 24285439
      5m 19.11s: got disc type 20
      5m 19.11s: type Blu-ray BDMV
      5m 19.11s: volume label AHS_S3_D1
      5m 19.11s: DriveX msg: add media in driveX J.
      5m 19.11s: DriveX msg: send open media msg to thread for driveX J.
      5m 19.11s: Source managerpen source flag:1,1,1,1,1
      5m 19.11s: Source manager: add source id 0.
      5m 19.12s: bd set region ?
      5m 19.12s: Source open statusVD Yes, 2223-7-6
      5m 19.12s: Source open status:BD Yes, 2223-7-6
      5m 19.12s: opening drive J
      5m 30.36s: opened i/o
      5m 30.93s: got max lba 24285439
      5m 42.47s: got disc type 20
      5m 42.47s: internal path J:/BDMV/
      5m 53.52s: aacs 1 bd+ 1
      5m 53.78s: got bdmv
      5m 54.06s: movie name: american horror story season 3 coven disc 1||ahs_s3_d1
      5m 54.13s: got agid 0
      5m 54.41s: sent host cert chal
      5m 54.49s: got drive cert chal
      5m 54.49s: BEC 0
      5m 54.49s: DRIVE_VENDOR 0x0074
      5m 54.91s: got drive key
      5m 54.91s: got host key signature
      5m 54.92s: verified drive signature
      5m 54.92s: verified host signature
      5m 55.44s: sent host signature and key point
      5m 55.44s: got bus key
      5m 55.49s: got volume id
      5m 55.49s: got volume id mac
      5m 55.49s: volume id is correct
      5m 55.49s: got vid
      5m 55.69s: blu-ray D9FA6EAD45FB73FD4554823AAE73DBAB1638B7C0
      5m 56.40s: cert BEE=0x80 same
      5m 57.54s: D 211BF413
      6m 31.07s: main playlist 00804.mpls
      6m 31.07s: selected region B
      6m 31.07s: bd set region B
      6m 49.29s: got vuk
      6m 49.29s: got fut
      6m 49.50s: got unit key 1
      7m 04.03s: got bdmv
      7m 11.12s: got extended bdinfo
      7m 11.12s: opened blu-ray
      7m 11.28s: Source manager: open successful.
      7m 23.59s: Work manager: create BD fulldisc work 0 with source 0 and uiinfo 0.
      7m 51.26s: UILog:OnMsgToolbar_Start
      7m 51.26s: UILog:Msg Start : ready start
      7m 51.26s: UILog:Msg Start : start test run work
      7m 51.26s: UILog:right button to null, work falg = -1
      7m 51.31s: UILog:Msg Start : run work
      7m 51.31s: UILog:Run current Work.
      7m 51.39s: UILog:Begin work copy or converter.
      7m 51.40s: UILog:start running at thread.
      7m 51.40s: UILog:return flag at start running at thread ok.
      7m 51.46s: BD FullDisc watermark flag: 0
      7m 51.47s: UILog:MsgWork:WorkStatus_Start
      7m 51.47s: Blu-ray Copy: Full Disc
      7m 51.47s: Source: J:/BDMV/
      7m 51.47s: SourceSize: 47184 MB
      7m 51.47s: RemoveHDAudio: 0
      7m 51.47s: OutputSize: 46100 MB
      7m 51.47s: OtherSize (CLPI, JAR, etc.): 134 MB
      7m 51.47s: OutputDisc: BDMV
      7m 51.47s: OutputTarget: BD50
      7m 51.47s: OutputVideo: 1080p/i
      8m 52.06s: Output group estimatedblock size
      8m 52.06s: video cannot be compressed
      23m 19.91s: read error: 11 1372800 7267565 4091583 602
      24m 06.70s: UILog:OnMsgToolbar_Stop
      24m 09.81s: UILog:MsgWork:current work finish : 4
        check and clean the disc if necessary. make sure that you are
        using the latest version of dvdfab which is 9.1.9.6
          I am using version 9.1.9.6 and there is nothing wrong with the disc.
            @ SNURBY1
            I have edited your post, we will have no more of that, this is your warning.
            Try cleaning the disc as october262 suggested, this may need an update from Fab for this disc or you may have a bad disc it is not uncommon.
            CBR929
              @ SNURBY1
              CBR929
              The disc is clean and it plays perfectly there are no marks on the disc I answered the previous user as they never bothered to look at the version I was using which is the latest version so really they contributed nothing at all towards my problem with this disc.
              So really apart from telling me it is a faulty disc and to use the latest version which I already have I could have come to the same conclusion I’m looking help october262 did not offer any help but instead told me what I knew already I’m looking help here so october262 would have been better to not have replied at all except to explain what was already a given, that’s all. So I am not allowed to give my opinion. Democracy my friend open and honest I do not molly coddle I tell it straight from the hip.
                Try version 8 and clean your mailbox out it's full.
                  There is something wrong with the disc! From your log: 23m 19.91s: read error: 11 1372800 7267565 4091583 602 the fact that it plays has nothing whatsoever to do with whether or not it will copy. The read error is either part of a protection scheme or a poorly manufactured disc. Take the good advice you've been given and watch the language!
