Not possible to set Blu-ray frame rate???
    Hi!
    In the Blu-ray Ripper I am not able to set the frame rate of any Blu-ray. There is only one option: "same as source". When there is a DVD I can change a wide range of frame rates (24, 25...).
    How can I change the frame rate for a Blu-ray? German Blu-rays are played with 24p instead of 25p in TV and DVD. So the voices of old films sound lower and slower. And so I want to "correct" the speed to 25p.
    Best wishes,
    Fiorello
    All films (movies) are shot with a frame rate of 24fps (sometimes 23.976 these days). When aired on any 25fps station (cable, OTA, satellite), it is sped up. You have gotten use to the sped up sound. The better conversions will also correct the audio pitch, but most don't.
    So, trying to speed it up to 25fps is not correcting it.
