"Closed caption "
    "Closed caption "
    I have just finished my fist two Movies 1 to hard drive the other to PSP.. Both have the Closed Captions activated .. How is this disabled..
    FYI this is MY very first attempt at this kind of Adventure
    Turn it off in the "Subpicture" option.
      It says "direct render to video" no option to turn off
        No. In the initial page, you have a pane with the subpicture selection on the right hand middle of the Fab window. Make sure that none of these are ticked.
        Also, you can turn it off by going to the Fab settings page (Little green tick, top RH of Fab window) and check "Do not preselect"
          I think I found it.. Thanks for the Quickness.. Now if I can figure the rest out Ill be all good
