DVDfab hangs
    DVDfab hangs
    I have upgraded to the latest version but had the same issue with the previous where you insert a disk and it tries to read it and just hangs. The program opens and the it starts reading the disk and will go indefinitely.
    what happens if you disable pathplayer? what disc are you trying to open?
      I disabled it and it still seems to hang on the Open DVD Source section. The movie is Xmen Origins Wolverine. However what is odd is that this happens easily 1 out of 5 discs.
