Is anybody having trouble with this movie? I have tried fab 9 and other software and the movie will copy okay but it fails to start the burn engine both fab burn and imgburn and another program I have all fail to start the burn engine
San Andreas
13:21:13 ImgBurn Version 2.5.8.0 started!
I 13:21:13 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 3)
I 13:21:13 Total Physical Memory: 1,047,276 KiB - Available: 456,808 KiB
I 13:21:13 Initialising SPTI...
I 13:21:13 Searching for SCSI / ATAPI devices...
I 13:21:14 -> Drive 1 - Info: PIONEER DVD-RW DVR-112L 8.25 (D (ATA)
I 13:21:14 -> Drive 2 - Info: PIONEER DVD-RW DVR-112L 8.25 (E (ATA)
I 13:21:14 Found 2 DVD±RW/RAMs!
I 13:21:17 Operation Started!
I 13:21:17 Building Image Tree...
I 13:21:18 Checking Directory Depth...
I 13:21:18 Calculating Totals...
I 13:21:18 Preparing Image...
I 13:21:18 Checking Path Length...
I 13:21:18 Contents: 9 Files, 2 Folders
I 13:21:18 Content Type: DVD Video
I 13:21:18 Data Type: MODE1/2048
I 13:21:18 File System(s): ISO9660, UDF (1.02)
I 13:21:18 Volume Label: RUN_ALL_NIGHT
I 13:21:18 IFO/BUP 32K Padding: Enabled
I 13:21:18 Region Code: 1, 2, 3, 4, 5, 6, 7, 8
I 13:21:18 TV System: NTSC
I 13:21:18 Size: 4,676,343,808 bytes
I 13:21:18 Sectors: 2,283,371
I 13:21:18 Image Size: 4,676,976,640 bytes
I 13:21:18 Image Sectors: 2,283,680
I 13:21:18 Operation Successfully Completed! - Duration: 00:00:00
I 13:21:18 Operation Started!
I 13:21:18 Source File: -==/\/[BUILD IMAGE]\/\==-
I 13:21:18 Source File Sectors: 2,283,680 (MODE1/2048)
I 13:21:18 Source File Size: 4,676,976,640 bytes
I 13:21:18 Source File Volume Identifier: RUN_ALL_NIGHT
I 13:21:18 Source File Volume Set Identifier: 47686AA80022D892
I 13:21:18 Source File Application Identifier: IMGBURN V2.5.8.0 - THE ULTIMATE IMAGE BURNER!
I 13:21:18 Source File Implementation Identifier: ImgBurn
I 13:21:18 Source File File System(s): ISO9660, UDF (1.02)
I 13:21:18 Destination Device: [1:0:0] PIONEER DVD-RW DVR-112L 8.25 (E (ATA)
I 13:21:18 Destination Media Type: DVD+R (Disc ID: MCC-004-00)
I 13:21:18 Destination Media Supported Write Speeds: 4x, 6x, 8x, 12x, 16x, 18x
I 13:21:18 Destination Media Sectors: 2,295,104
I 13:21:18 Write Mode: DVD
I 13:21:18 Write Type: DAO
I 13:21:18 Write Speed: 8x
I 13:21:18 DVD+R Reserve Track: No
I 13:21:18 Link Size: Auto
I 13:21:18 Lock Volume: Yes
I 13:21:18 Test Mode: No
I 13:21:18 OPC: No
I 13:21:18 BURN-Proof: Enabled
I 13:21:18 Write Speed Successfully Set! - Effective: 11,080 KB/s (8x)
I 13:21:18 Advanced Settings - Optimal Writing Speed: No
I 13:21:19 Filling Buffer... (40 MiB)
I 13:21:20 Writing LeadIn...
W 13:21:38 Failed to Write Sectors 768 - 799 - Reason: Power Calibration Area Error
W 13:21:38 Retrying (1 of 20)...
W 13:21:38 Retry Failed - Reason: Invalid Address For Write
W 13:21:38 Retrying (2 of 20)...
W 13:21:38 Retrying (3 of 20)...
W 13:21:38 Retrying (4 of 20)...
W 13:21:38 Retrying (5 of 20)...
W 13:21:38 Retrying (6 of 20)...
W 13:21:38 Retrying (7 of 20)...
W 13:21:38 Retrying (8 of 20)...
W 13:21:38 Retrying (9 of 20)...
W 13:21:38 Retrying (10 of 20)...
W 13:21:38 Retrying (11 of 20)...
W 13:21:38 Retrying (12 of 20)...
W 13:21:39 Retry Failed - Reason: Invalid Address For Write
W 13:21:39 Retrying (13 of 20)...
W 13:21:39 Retrying (14 of 20)...
W 13:21:39 Retrying (15 of 20)...
W 13:21:39 Retrying (16 of 20)...
W 13:21:39 Retrying (17 of 20)...
W 13:21:39 Retrying (18 of 20)...
W 13:21:39 Retrying (19 of 20)...
W 13:21:39 Retrying (20 of 20)...
E 13:25:15 Failed to Write Sectors 768 - 799 - Reason: Power Calibration Area Error
E 13:25:15 Next Writable Address: 0
I 13:25:15 Synchronising Cache...
W 13:25:23 User opted to skip the 'Close Track/Session/Disc' functions.
E 13:25:23 Failed to Write Image!
E 13:25:25 Operation Failed! - Duration: 00:04:04
I 13:25:25 Average Write Rate: 0 KiB/s (0.0x) - Maximum Write Rate: 0 KiB/s (0.0x)
I 13:25:31 Close Request Acknowledged
I 13:25:31 Closing Down...
I 13:25:31 Shutting down SPTI...
I 13:25:31 ImgBurn closed!Paid Not To Work
US Navy Retired ( 20 Years )
Proudly Served On
USS Coral Sea CVA-43 (VF-154) / USS Oriskany CVA-34 (VFP-63) / USS Ranger CVA-61 (VF-121)
6 trips to the Gulf Of Tonkin
try cleaning your laser lens on your dvd drive.
check and see if the firmware is up to date for your burner.
try burning your discs at 4x speed.
also try - click (common settings) - (drives) - (dvd write)
and put check mark where it says (set book type to dvd-rom)Last edited by october262; 11-08-2015, 09:54 PM.
Lens clean, always set for dvr rom for +R's firmwar was flashed from a 112D using buffalo to a 112L FW 8.25 years ago, they will read and play ok just wont copy. So what does the invalid address for write mean? I have reinstalled ver 5, 6, 8, 8QT and 9 and all the same won't writePaid Not To Work
Proudly Served On
using the search box here in the forum, some
say it may also be caused by a slowly dying burner.
or you may have a bad batch of blanks.
go up to where it says search at the top and enter - Power Calibration Area Error
could also try to reinstall your dvd drives.Last edited by october262; 11-09-2015, 12:29 AM.
what puzzles me is that I get the message invalid address for write this happens on fab ver 5,6,8,8QT and 9 so it seems that fab isn't picking the right address to write from but I checked it and it's ok and on the target on ver 9 I have the drive listedPaid Not To Work
Proudly Served On
in the imgburn settings, have you tried the reset DMA and restore default settings??
also try restore default settings in dvdfab.Last edited by october262; 11-09-2015, 11:58 PM.
Hi Jimbo
Have you tried both burners with the same result?
Give this a read through http://www.megaleecher.net/Fix_Power_Calibration_Error
If using ImgBurn click settings> write> check the box perform OPC before write, see pic.
Hope this helps.
CBR929Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
CBR: you be da man it worked with imgburn (opc) checked, the inst I read setting up imgburn had you unchecking it for FAB so all is good with ONLY imgburn, fab burn engine and vso doesn't burn though anyway thanks a million bud, I owe youPaid Not To Work
Proudly Served On
Glad to help my friend. 👍Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
