target
    target
    when i try to do dvd to dvd it only puts it on my hard drive and wont let me put it on a dvd i think it has some thing to do with the target box in the guide it has a dvd symbol mine has a file symbol
    The folder symbol is ok if the optical drive is in the dropdown window. If it's not click the little down arrow and select it. The DVD symbol will be adjacent to your drive letter and appear inside the box.
      jctanner
      I deleted your duplicate thread.
      Do not start more than one thread on the same subject.
