ISO Files
    ISO Files
    Does anyone know if I can burn ISO files using DVDFab? I can't seem to find any option screen that allows me to do this and have some disk image files I would like to burn.
    Sure you can.
    Simply select the .ISO icon on the far right of Source (looks like a dogeared piece of paperpaper with a disc overlay).
    It's just to the right of the Folder icon
      And use the "Write Data" mode.
        Okay, Got it. But now I can't figure out why it ten defaults to trying to write a BluRay disk. So I select the Write Data mode and then click on the dogeared paper/disk icon which opens a dialog box and I select my file. At this point it expands the BluRay menu and asks for the region I am using. But it isn't a BluRay file, nor do I even have a BluRay drive. That odd!
        Thoughts?
          How big is the image file., in gigabytes?
            What created the iso you're trying to burn?
