Is there an option to prevent 'Fab from auto scanning of disk drives upon startup/disc insertion?? I have 5 drives and run multiple instances of 'Fab and it can mess things up when a new instance/disk insertion occurs. I just want to manually load which disks get used by a given instance. I normally run 2 instances copying and 1 ripping.
Also is there a way to have GPU of a secondary graphics card be used for ripping in one instance and my IQS used by another. I have 3 monitors. It seems that ripping is the process that slows stuff down since running 2 instances of ripping slows by more than half sharing IQS. I write ISOs to hard drive and rip from the ISOs so I can reload the drives for copying.
I know at least the latter is truly wishful thinking, but you never know .....
Kevin
