Bluray to DVD Failure
    Every attempt I have made at using the bluray to dvd feature has failed. It doesn"t matter which movie I try, it still fails. It will show progress copying/converting the bluray up to the point that it completes the first part (copying bluray), then the program will pop up with an error stating that dvdfab has encountered a problem and needs to close before it burns the dvd. Error reporting will not work either when it stops working. I hit send, and it does nothing. My only option is to hit OK and let it close the program.
    Using Windows Vista 64 and an LG Bluray multi-burner on a HP Pavilion Media PC.
    DVDFab version 9.2.3.1
    Any help is appreciated. I bought the additional lifetime version of the bluray to dvd, and at this point, it is totally useless to me.
    Thank you for the input.
    please post the dvdfab internal log files
    and the burn log files.
      Not sure if this is what you want to see?
      1m 36.20s: opening drive F
      1m 36.20s: opened i/o
      1m 36.20s: got media type 15
      1m 37.19s: got max lba 19915455
      1m 37.97s: got disc type 20
      1m 37.97s: type Blu-ray BDMV
      1m 37.98s: volume label THE_GOOD_DINOSAUR
      1m 37.98s: DriveX msg: add media in driveX F.
      1m 37.98s: DriveX msg: send open media msg to thread for driveX F.
      1m 37.98s: Source managerpen source flag:1,1,1,1,1
      1m 38.00s: Source manager: add source id 1.
      1m 38.01s: bd set region ?
      1m 38.01s: Source open statusVD Yes, 2231-10-11
      1m 38.01s: Source open status:BD Yes, 2231-10-11
      1m 38.01s: internal path F:/BDMV/
      1m 38.29s: aacs 1 bd+ 0
      1m 38.56s: got bdmv
      1m 59.76s: opening drive G
      1m 59.79s: opened i/o
      1m 59.79s: got media type 5
      1m 59.79s: got max lba 0
      1m 59.79s: DriveX msg: media open(false) failed in driveX G.
      2m 16.09s: movie name: the good dinosaur||the_good_dinosaur
      2m 16.09s: got agid 0
      2m 16.11s: sent host cert chal
      2m 16.11s: got drive cert chal
      2m 16.11s: BEC 0
      2m 16.11s: DRIVE_VENDOR 0x0074
      2m 16.14s: got drive key
      2m 16.15s: got host key signature
      2m 16.15s: verified drive signature
      2m 16.15s: verified host signature
      2m 16.18s: sent host signature and key point
      2m 16.18s: got bus key
      2m 16.18s: got volume id
      2m 16.18s: got volume id mac
      2m 16.18s: volume id is correct
      2m 16.18s: got vid
      2m 16.53s: blu-ray 0816E40636AD212C5A6794A110A95F56E3A4706F
      2m 16.98s: cert BEE=0x00 same
      2m 17.46s: D 22C0A16F
      2m 17.46s: main playlist 00800.mpls
      2m 17.46s: selected region A
      2m 17.46s: bd set region A
      2m 17.47s: got vuk
      2m 17.47s: got unit key 7
      2m 18.46s: StealthyClone with BluPath
      2m 30.25s: got bdmv
      3m 22.87s: got extended bdinfo
      3m 22.87s: opened blu-ray
      3m 23.21s: Cinavia : no cinavia repair data.
      3m 23.22s: Source manager: open successful.
      3m 25.20s: Work manager: create BD mainmoive work 1 with source 1 and uiinfo 1.
      3m 30.66s: UI manager: switch to Convert mode.
      3m 42.49s: UI manager: switch to Copy mode.
      4m 02.45s: Work manager: create BD to DVD work 2 with source 1 and uiinfo 2( title 800 ).
      4m 02.71s: ========WorkAttr::SetSource=======
      4m 02.71s: Source Video Size Original : 1920 x 1080
      4m 02.71s: Source Video Size Display : 1920 x 1080
      4m 02.71s: Source Video FPS : 24000 / 1001
      4m 02.71s: Source Video Bitrate : 1200
      4m 02.71s: Source Audio Bitrate : 0
      4m 02.71s: Source Audio Channels : 8
      4m 02.71s: Source Audio Volume : 100
      4m 02.71s: Work Profile : DVD_VOB
      4m 50.19s: UILog:OnMsgToolbar_Start
      4m 50.21s: UILog:Msg Start : ready start
      4m 50.27s: UILog:Msg Start : start test run work
      4m 50.28s: UILog:right button to null, work falg = -1
      4m 50.65s: UILog:Msg Start : run work
      4m 50.65s: UILog:Run current Work.
      4m 51.09s: UILog:Begin work bd to dvd.
      4m 51.12s: OPList at BD Converter : (4113.2),(4352.2),(4353.2),(4354.2),(4355.2),(4358 .2),(4608.32),(4609.32),(4612.32),(4613.32)
      4m 51.12s: Blu-ray Converter (3D Plus) check watermark flag: 0
      4m 51.14s: Blu-ray to DVD output is: DVD5 4m 51.14s: UILog:start running at thread.
      4m 51.15s: UILog:return flag at start running at thread ok.
      4m 56.18s: Menu template name:01movie
      4m 56.18s: Output disc type is : DVD5
      5m 00.20s: Burn data size is: 4488
      5m 00.20s: Burn disc space is: 4488
      5m 00.25s: ------------------ convert work begin(1/1) ------------------
      5m 00.26s: create config(bluray2video)
      5m 00.27s: info: crop value after clone: left = 0 right= 0 top=0 bottom=0 enable=0 mode=0
      5m 00.27s: info: use profile(DVD_VOB)
      5m 00.27s: info: bluray playlist(800),angle(0),chapter(1->30),BDAV(no)
      5m 00.27s: info: 3D working_mode(disable), 3D format(sbs_lef_right)
      5m 00.33s: info: stream input@ Video(4113)[codec(h264) size(1920*1080) fps(24000/1001) interlace(0) duration(45)sec opcode(compress)]
      5m 00.33s: info: set output video frame_rate(24000/1001)
      5m 00.33s: info: vdecode hevc= 0, h264= 0, vc1= 0, mpeg2= 0, vencode h264= 0, hevc= 0
      5m 00.34s: info: stream output Video(4113)[codec(mpeg2video) size(720*480) fps(24000/1001) interlace(0) bitrate(4313) duration(45)sec]
      5m 00.34s: info: stream input@ Audio(4352)[codec(dca) channels(8) sample(48000) bitrate(0) bitdepth(24) opcode(compress)]
      5m 00.36s: info: stream output Audio(4352)[codec(ac3) channels(6) sample(48000) bitrate(448000) bitdepth(16) opcode(compress)]
      5m 00.36s: info: stream input@ Audio(4353)[codec(dca) channels(6) sample(48000) bitrate(2046000) bitdepth(24) opcode(compress)]
      5m 00.38s: info: stream output Audio(4353)[codec(ac3) channels(6) sample(48000) bitrate(448000) bitdepth(16) opcode(compress)]
      5m 00.38s: info: stream input@ Audio(4354)[codec(ac3) channels(2) sample(48000) bitrate(320000) bitdepth(0) opcode(compress)]
      5m 00.40s: info: stream output Audio(4354)[codec(ac3) channels(2) sample(48000) bitrate(448000) bitdepth(16) opcode(compress)]
      5m 00.40s: info: stream input@ Audio(4355)[codec(ac3) channels(2) sample(48000) bitrate(320000) bitdepth(0) opcode(compress)]
      5m 00.41s: info: stream output Audio(4355)[codec(ac3) channels(2) sample(48000) bitrate(448000) bitdepth(16) opcode(compress)]
      5m 00.42s: info: stream input@ Audio(4358)[codec(ac3) channels(2) sample(48000) bitrate(320000) bitdepth(0) opcode(compress)]
      5m 00.43s: info: stream output Audio(4358)[codec(ac3) channels(2) sample(48000) bitrate(448000) bitdepth(16) opcode(compress)]
      5m 00.44s: info: stream input@ SubPicture(4608)[codec(pgssub) language(English) opcode(remux)]
      5m 00.44s: info: stream output SubPicture(4608)[codec(dvdsub) language(English)]
      5m 00.44s: info: stream input@ SubPicture(4609)[codec(pgssub) language(English) opcode(remux)]
      5m 00.44s: info: stream output SubPicture(4609)[codec(dvdsub) language(English)]
      5m 00.44s: info: stream input@ SubPicture(4612)[codec(pgssub) language(English) opcode(remux)]
      5m 00.44s: info: stream output SubPicture(4612)[codec(dvdsub) language(English)]
      5m 00.44s: info: stream input@ SubPicture(4613)[codec(pgssub) language(English) opcode(remux)]
      5m 00.44s: info: stream output SubPicture(4613)[codec(dvdsub) language(English)]
      5m 00.45s: info: SubMode(Remux) -- Display Only forced Subtitle(false)
      5m 00.46s: UILog:MsgWork:WorkStatus_Start
      5m 00.46s: info: enable multi-thread software decoder, thread count = 4
      5m 00.50s: info: processing source(00301.m2ts)
      5m 33.21s: info: bluray read data end
      5m 33.21s: info: processing source(00302.m2ts)
      5m 33.22s: warning: repeat frame remove pes pack (4352)(1048560)
      5m 33.22s: warning: repeat frame remove pes pack (4353)(1048560)
      5m 33.24s: warning: repeat frame remove pes pack (4352)(1048560)
      5m 33.24s: warning: repeat frame remove pes pack (4353)(1048560)
      5m 54.89s: info: bluray read data end
      5m 54.93s: info: processing source(00303.m2ts)
      6m 21.51s: info: bluray read data end
      6m 21.51s: info: processing source(00304.m2ts)
      6m 50.20s: info: bluray read data end
      6m 50.21s: info: processing source(00305.m2ts)
      83m 21.91s: info: bluray read data end
      83m 21.95s: info: processing source(00306.m2ts)
      89m 58.33s: info: bluray read data end
      89m 58.33s: info: processing source(00307.m2ts)
      89m 58.34s: warning: repeat frame remove pes pack (4352)(1048560)
      89m 58.34s: warning: repeat frame remove pes pack (4353)(1048560)
      90m 21.28s: info: bluray read data end
      90m 21.30s: info: audio_decode finish job
      90m 21.30s: audio_encode finish job
      90m 22.33s: info: audio_decode finish job
      90m 23.33s: audio_encode finish job
      90m 30.76s: error: filter name(filter_mux_mpeg), type(128), id(34), get fatal exception
      0m 00.05s:
