DVDfab: Default target location
    Where can I set the default target location. Currently every time I start DVDfab it defaults to my burner. I would like it to default to my Hard Drive location.
    I had it doing that in a previous version but now i can't find the option to change the default.
    Thanks for the help.
    Via the Green Check mark, top right
    On the "General" setting form "Output Directory" ....
    Also check the DVD to DVD settings form, Default Output Type, should be "DVD Folder"
    EDIT/FYI: The name dysan seems very familiar to me for some reason .... also welcome to the forum
    AX
    The default Log File location: C:\Documents and Settings\"User Acct"\My Documents\DVDFab\Log
      Also, under Settings->DVD, make sure that you set the output type to "DVD Folder" and you can also set your default DVD5/DVD9 here.
