Copy speed
    Other Copy speed
    How do I change the copy speed? I can't find any place to change it. It copies at 1.9 mbs.
    Thanks
    It is dependent on your hardware.
      I found it.
      Thanks
        I found it.
        And where might that be?
          Yeah I'm wondering what he found too?
            Open Common Settings, then tic Drives, then look on left side and tick DVD Write, then you will see it.
              Therein lies the problem. You asked about copy speed and that is a read operation. You were really asking about the write speed.
