older versions
    older versions
    i have a folder with older versions of dvdfab9 but dont have the versions 9237 or 9239 is it possible to get those versions (download) please. 9242 seems to be bugged, wont copy a movie keeps failing (tried both full and main selected)
    Corsair 800D case | Corsair AX1200i psu | Asus Rampage IV Extreme | I7 4820k ivy bridge @ 4.5GHZ w/corsair GTX h100I | CORSAIR vengeance 32GB DDR3 1600 | EVGA GTX Titan X SC | (2) Corsair Force Series GS SSD- 240GB ea. SATA III | (2) WD VelociRaptor 600GB 32MB Cache | Lite-on Blu-ray burner w/3d | SB-Z Series | 29" LG 21:9 UltraWide IPS LED Monitor | 27" Acer 3d 1080p | win10 Pro 64bit
    Hi briancowen
    If you really need 9237 and 9239 send me a pm with your e-mail address and I will send them to you.
    Remember that you will not get support using older versions.
    CBR929
      Would you please tell us more details for your problem and post the DVDFab log files?
