play 3d iso from laptop on 3d TV
    Other play 3d iso from laptop on 3d TV
    Hello,
    I need your help guys. I try to watch a 3d movie from my laptop (acer Aspire V15 Nitro) on a Samsung 3D TV (48H6400). The movie is an iso (image) and DVDFAB Media Player will play it 2d when I connect my laptop to tv with HDMI cable. The 3D button in media player is grey(inactive).
    Can somebody help me withthis problem? What should I do to watch the movie in 3D, some settings or other software?
    Thank you
    Do you have the latest version of media player
    Installed? ? - version 2.5.0.5
    UPDATE: it seems the dvdfab media player doesn't
    Support 3D playback yet.
      If you want to watch the iso in full 3d you need a software player that plays full 3d like Power dvd version 11 on up however if you want a Fab solution until Fab supports full 3d on its media player you can make a side by side 3d movie from the 3d iso and most any blu ray software player will play it.Try a 3d mkv side by side you can keep the HD soundtrack then play it in 3d.Just make sure you put the tv or projector in side by side 3d mode.
