If I turn OFF the "Export Blu-ray information" feature in Common Settings>Blu-Ray>Blu-Ray information the C:\BDInfo folder is still created. If I delete it, it's recreated every time I start DVDFab.
If I change the folder to (For example), "F:\Temp\BDInfo" after turning the feature on, then exit DVDFab the setting reverts to C:\BDInfo after exiting/Restarting DVDFab.
I may be able to disable the feature, but I cannot stop DVD Fab creating the folder in the root of my C: drive (which IMHO is the wrong place to put it anyway - Possibly C:\ProgramData\DVDFab\BDINfo???)
I'm using v9.3.0.3. OS Is Windows 7 x64.
