DVDFab 9.3.1.2 Convertor Freezes 43% into VOB
    Performance DVDFab 9.3.1.2 Convertor Freezes 43% into VOB
    Attempting to convert VOB files spinning on the disk using CUDA and the Convertor software using h.265 mp4 profile.
    Using the merge function (I'm assuming that is how to output one video from multiple VOBs), DVDFab will freeze up about 42% into the first VOB. An interesting observation is the mp4 output file is always at the same size, around 88 megs.
    If I turn CUDA off, DVDFab works as expected.
    I attached the log file to this posting. This was taken from the DVDfab_internal.log file. The last entry in the file.
    If you're using the DVD disc as the source use "Ripper" for this conversion.
