I've run into something new to me and have not found a reference to it any where. I am putting the series "Vikings" from the History Channel onto my harddrive. I only want the shows and none of the other stuff. The problem I am having is there are more files listed than fit in the blu-ray ripper window. I have expanded the window as far as it will go (top to bottom, 23 lines). I do not see a scroll bar. Is there a way to scroll? Or see the rest of the list?
Thankyou
Mark
Thankyou
Mark
