It seems lately I'm spending more time waiting to burn a disc. The burning will stop and it says... waiting for buffers to recover. It will do this 3 or 4 times before the disc is finished. Does anyone know what causes this?
Check that your dvd burner has the latest firmware update.
Also what brand of blank disc's do you use ??
And what burning engine you use. Post the dvdfab internal log files
And the burn log files. And your drive may have slipped into PIO
Mode.
Hi Ernie
Are you using ImgBurn as your burn engine?
If so open ImgBurn tools>settings>build>page 2>read buffer size>slide cursor to 200, next click I/O tab>page 2 buffer size>slide cursor to 200 click OK and try again.
