DVDFab 10 not opening iso folder
    Other DVDFab 10 not opening iso folder
    DVDFab 10 is not opening the target folder after imgburn has made the iso file. I can't see a setting for this and I would like to have the same functionality as DVDFab 9, so how do I turn it on?
    'Round, 'round, get around... I'm getting dizzy
    bambee can you not click on "+add" and browse to the folder?
      Please click the folder icon to open the target folder manually in the Task Queue after finished the task.
      Please check the option in Common Settings if you want DVDFab to open the target folder directly after finished the task.
      See the attached pic.
