DVD FAB 10.0.1.6 crashes frequently after I have ripped a few movies. Typically, BD Rip main movie...
The task starts but then you check a hour or 12 hours later and you see DVDFAB is no longer responding.
My normal use scenario is start DVDFAB leave it running and once one disc is done click finish and then put a new disc in. After a day or two (3-4 disc's a day) DVDFAB crashes.
2350m 30.13s: MoviePoster Log: Volume(BEN-HUR), DiscID(BDD5F2E7EE779452100119CF8), Result(C:/Users/Nathan/Documents/DVDFab10/Temp/MediaServer/A4xbEpe9LevQCdvaNC0z6r8AfYk.jpg)
2350m 30.13s: Cinavia: no cinavia repair data.
2350m 30.79s: Meta: the ownership is E_Meta_Is_Not_Owner.
2350m 30.79s: Source manager: open successful.
2350m 31.40s: Meta: editable flag is META_INFO_EDITABLE_FLAG_NONE
2350m 31.41s: Meta: Load meta info data from server.
2350m 32.38s: Work manager: create BD mainmoive work 2 with source 2 and uiinfo 2.
2350m 32.46s: Source manager: open source flag:1,0,1,1,1
2350m 41.57s: UILog: OnMsgToolbar_Start
2350m 41.58s: UILog: Msg Start: ready start
2350m 41.58s: start work: after CheckCinaviaConfigs: line 3261
2350m 41.58s: start work: after activeWorkQueueDlg: line 3269
2350m 41.58s: start work: after saveScene: line 3273
2350m 41.58s: start work: after FabMsg::Msg_PageCtrl_Update, FabMsg::ToolBar_Msg_Start: line 3302
2350m 41.58s: UILog: Msg Start: start test run work
2350m 41.58s: UILog: Msg Start: run work
2350m 41.58s: UILog: Run current Work.
2350m 42.72s: UILog: Begin work copy or converter.
2350m 42.72s: UILog: start running at thread.
2350m 42.72s: opening drive D
2350m 42.72s: opened i/o
2350m 42.72s: got media type 15
2350m 49.88s: got max lba 17845759
2351m 21.13s: got disc type 20
2351m 21.13s: type Blu-ray BDMV
2351m 21.13s: volume label Ben_Hur
2351m 21.13s: UILog: return flag at start running at thread ok.
2351m 21.19s: BD MainMovie watermark flag: 0
2351m 21.19s: UILog:MsgWork:WorkStatus_Start
2351m 21.20s: UILog:MsgWork:WorkStatus_Start
------ process working ------
0m 00.10s: opening drive D
0m 00.12s: opened i/o
0m 00.12s: got media type 15
0m 07.21s: got max lba 17845759
0m 38.43s: got disc type 20
0m 38.43s: type Blu-ray BDMV
0m 38.43s: volume label Ben_Hur
0m 38.43s: bd set region A
0m 38.43s: opening drive D
0m 38.88s: opened i/o
0m 46.07s: got max lba 17845759
1m 17.30s: got disc type 20
1m 17.30s: internal path D:/BDMV/
3m 58.06s: aacs 1 bd+ 0
5m 50.68s: got bdmv
5m 51.13s: got agid 0
5m 51.20s: sent host cert chal
5m 51.24s: got drive cert chal
5m 51.24s: BEC 1
5m 51.24s: DRIVE_VENDOR 0x0073
5m 51.29s: got drive key
5m 52.32s: got host key signature
5m 52.32s: verified drive signature
5m 52.32s: verified host signature
5m 52.37s: sent host signature and key point
5m 52.37s: got bus key
5m 52.42s: failed to get volume id: sensekey 05 asc 6F acsq 02
5m 55.56s: blu-ray 11BE44F829B791AF35AB07DBCBA935A941EA9B94
6m 12.45s: cert BEE=0x80 same
6m 12.76s: D 62396A75
6m 12.76s: E 6B1E272D
6m 12.76s: main playlist 00800.mpls
6m 12.76s: selected region A
6m 12.76s: bd set region A
6m 12.76s: got vuk
6m 12.77s: got agid 0
6m 12.85s: sent host cert chal
6m 12.90s: got drive cert chal
6m 12.90s: BEC 1
6m 12.90s: DRIVE_VENDOR 0x0073
6m 12.90s: AACS bus encryption is enabled
6m 12.96s: got drive key
6m 12.96s: got host key signature
6m 12.96s: verified drive signature
6m 12.96s: verified host signature
6m 13.04s: sent host signature and key point
6m 13.04s: got bus key
6m 13.07s: failed to read data key: sensekey 05 asc 6F acsq 02
6m 13.09s: failed to open 209
2887m 09.70s: UILog: OnMsgToolbar_Stop
0m 00.01s:
5m 50.68s: got bdmv
5m 51.24s: BEC 1
6m 12.76s: got vuk
6m 12.90s: BEC 1
0m 00.01s:
