Which Product? Join mp4 files
    Other Which Product? Join mp4 files
    Is there a DVDFab product that will join two (or more) files into one. For example I have two *.m4v files that I want to make into one *.m4v file. Can this be done? If so, which product will do that.
    Thanks.
    "Ripper" will do that. the output file will be MP4, if you must have m4v it's just a matter of changing the file extension.
      I have Blu-Ray Ripper and I don't see how to combine two video formatted files. The Ripper asks for ISO or a folder. So I put my two target *.m4v files into a new folder and tried to have Ripper access that folder to no avail.
      Am I missing something, or ...
      Thanks for viewing (and answering)
        Drag and drop or click "add" so that both files are in the work space and then click "merge". See attached:
        If they're already in mp4 format use converter:
          Thanks @90312
          It's the Converter I'll need as they target's have already been ripped.
            Your welcome! Let us know how you make out.
