DVDFab 10.0.2.7 crashes on Win10 64bit when trying to rip
    Other DVDFab 10.0.2.7 crashes on Win10 64bit when trying to rip
    I just updated to DVDFab 10.0.2.7 and I can't rip any more. The ripping process begins and after a few seconds it crashes and shows the windows to send the log files to the developers.
    It was working just fine until the update with the previous version.
    I tried a clean re-install of the program and still getting the same problem.
    I've sent the log files now through the "Process Failed" window. Do I need to do anything more?
    Regards,
    Mario
    Are you running dvdfab " as administrator " ??
    Try checking your Antivirus / Spyware software As sometimes These can prevent dvdfab from running properly.
      Yes I did both (run as admin and complete turn off anti-virus etc) and still I get the process failed window. I also tried to install it on another Win10 64 bite PC with the same problem.
        Do a clean Uninstall of dvdfab and run a good registry cleaner
        Restart your computer and try reinstalling Dvdfab.
          Yes, that has been done as well (I mentioned this already). Same behavior, it still crashes.
            Post the internal log files
              Internal log files....
              ...here you can also see that it was working until the last version.
              And also thanks for the help!
              Cheers,
              Mario
