DVDFab 8 QT and Win 10 Upgrade
    Other DVDFab 8 QT and Win 10 Upgrade
    I recently upgraded my Gateway I7 System to Windows 10. My DVDFab 8 QT stops responding after selecting "start DVDfab". I had no problems running under Windows 7 Professional. I tried selecting "run in compatibility mode but experience the same problem. Is there a compatibility problem with Windows 10 and earlier versions of DVDFab. I prefer the earlier version because it loads fast and handles most of my copy needs.
    System...Gateway FX6803 I7 930 64kb op sys w/8gb memory
    Are you running dvdfab " as administrator " ??
    Make sure that your computer has all the latest updates
    And your computer's graphics card has the latest driver update.
    Also check your Antivirus / Spyware software and your firewall.
