Prior versions of DVDFab -- Where?
    Purchase Problem Prior versions of DVDFab -- Where?
    Hello,
    Where can I find prior versions of DVDFab? The latest (version 10.0.3.2) is too new. I don't like to install the very latest versions.
    Thanks so much,
    CS.
    Hi Cuddly Squid
    Though it is not suggested to use older versions of DVDFab because they are not supported you could try google searching "old versions of DVDFab". This is one of the sites that will pop up http://www.filehorse.com/
    If you do not feel comfortable downloading from sites that you do not know, "which I do not blame you" you could send me a pm with your e-mail address and I will send you the version you need, as I keep all Fab versions in a folder on my computer.
    CBR929
      You can also get version 8 &9 here - http://www.dvdfab.cn/download.htm?trackID=navmenu
