Have been having issues with the Full disc Blu-ray copy function for a while now. When attempting to copy full disc to BD25 the processing stops cold at 2% and the Time Remaining counter shoots up to 12-13 hours left before the program either errors out or crashes. This has been happening with nearly every Blu-ray I've tried for the past three months. Running ver. 10.0.3.2 on Windows 10 32-bit.
DVDFab 10.0.3.2 (2017/04/03 17:35:32)
0m 00.05s: Init Public log: enabled.
0m 00.05s: Init Private log: finish.
0m 00.06s: App info: 2017-4-1
0m 00.06s: App info: 10.0.3.2 10032 Official
0m 00.11s: Init CrashReportSettings: enabled.
0m 00.11s: Init DVDInfo_Log: enabled.
0m 00.11s: app args: count 1,arg 0:C:\Program Files (x86)\DVDFab 10\DVDFab.exe,
0m 00.11s: Init Qt_Log: disabled.
0m 00.59s: Profile Manager :: Begin Load Profile
0m 00.60s: SUCCEED: IServerService WebServer Init succeed.
0m 00.60s: SUCCEED: IServerService MediaLibrary Init succeed.
0m 00.96s: Qt Translator file load success
0m 00.96s: App info: client type 22.
0m 00.98s: MobilePlay load: preload successful.
0m 01.04s: MobilePlay load: Load successful.
0m 01.05s: set code page: .0
0m 01.05s: Init process: Transfer settings successful.
0m 01.05s: info: check logpath= C:/Users/Logandog/Documents/DVDFab10/Log/
0m 01.06s: info: _check_gpu is running ...
0m 02.63s: Profile Manager :: End Load Profile
0m 02.70s: info: check_gpu run successful
0m 02.71s: info: recommand= 8248, Shrink support= 1, enable= 1, cuda_cap= 1 , cpu_count= 4
0m 02.71s: GPU check: GPUAccelerate-0X203F
0m 02.71s: GPU check: GPUAccelerate setting-0X2038, 0X2038
0m 02.71s: GPU check: CUDA cap-0X1
0m 02.71s: GPU check: Support coreavc decode-0
0m 02.71s: GPU check: Lighting shrink status-1, 1
0m 02.71s: GPU check: Graphics info 1: NVIDIA GeForce GT 740 : 21.21.13.7653 : 3.0
0m 02.71s: Init process: Load config successful.
0m 02.71s: Init process: Windows os type is 64bit System Windows 10 Build 14393.
0m 02.72s: Init process: command line in is
0m 02.86s: Reg check: Parse string: ( 2:8260762964 )( 11:8260762964 )( 21:8263532095 )( 22:8263532095 )( 20:8263532095 )( 60:8260762964 )( 50:8260762964 )( OV:10032 )( BV:10030 )( S:52726db910f1a790f27037159eb6c852 )
0m 02.87s: Reg check: Option check status-Local
0m 02.87s: Reg check: ( HD Decrypter:1:0 )-( DVD to DVD (Gold):1:0 )-( DVD to DVD:1:1 )-( DVD to Mobile:1:1 )-( Blu-ray to Blu-ray:1:1 )-( Blu-ray to Mobile:1:1 )-( File to Mobile:1:1 )-( Blu-ray to DVD:1:1 )-( DVD to Blu-ray:1:0 )-( File to DVD:1:0 )-( File to Blu-ray:1:0 )-( File Mover:1:0 )-( Blu-ray to 3D:1:1 )-( 2D to 3D:1:0 )-( Blu-ray Decrypt:1:0 )-( DVD Decrypt:1:0 )-( CinaviaRemoval HD:1:0 )-( DVD Cinavia Removal:1:0 )-( Blu-ray Cinavia Removal:1:0 )-( DRM Removal:1:0 )-
0m 02.87s: App info: language type ENU.
0m 02.87s: App info: Install path C:/Program Files (x86)/DVDFab 10/
0m 02.87s: Init process: Set account info to DriveX.
0m 02.88s: Export Blu-ray source information report: enabled
0m 02.88s: Init process: Init GPU settings successful.
0m 02.88s: connect plugin info: start.
0m 03.07s: Reg check: Times of cinavia connecting error is: 0
0m 03.07s: Reg check: Start get sys number.
0m 03.08s: Reg check: Serial number is: 00-26-55-49-66-36:00-ff-b9-8b-2e-2a:00-26-82-2d-e5-78
0m 03.08s: Reg check: Connect type is: 0
0m 03.58s: Reg check: Times of connecting error is: 0
0m 03.58s: Reg check: Parse string: ( S:a90863e04f7949e90ee7cd2fbfeadf76
0m 03.58s: Reg check: Option check status-NewWork
0m 03.90s: connect plugin info: 1:1
0m 06.67s: Burn engine: start init.
0m 06.68s: Burn engine: set log folder.
0m 06.68s: DVD: init read settings.
0m 06.68s: DVD: init write settings.
0m 06.79s: BD: init read settings.
0m 06.79s: BD: init write settings.
0m 06.79s: bd set region A
0m 06.79s: Burn engine: config engine type-0 begin.
0m 06.79s: Burn engine: config engine type-0 end.
0m 06.79s: Burn engine: writer count 2.
0m 06.79s: Burn engine: 0- E:\ [hp CDDVDW TS-H653R 0E00 (Scsi)].
0m 06.79s: Burn engine: 1- F:\ [HP BD Writer bd335i QH22 (Scsi)].
0m 06.79s: Burn engine: end init.
0m 07.75s: Init process: Init setting page successful.
0m 07.75s: QtLog Mode = false
0m 08.34s: Start show MainUI.
0m 08.34s: dpi scale: x scale 1.000000
0m 08.34s: dpi scale: y scale 1.000000
0m 08.44s: Init process: init main ui successful.
0m 08.56s: UI manager: switch to Copy mode.
0m 08.58s: Init process: show main ui successful.
0m 08.59s: DriveX msg: Init driveX E with I/O mode: 0
0m 08.59s: DriveX msg: Init driveX F with I/O mode: 0
0m 08.59s: opening drive F
0m 08.59s: opened i/o
0m 08.59s: got media type 15
0m 08.62s: scene data: delete file C:/Users/Logandog/Documents/DVDFab10/SceneData/34736900-fd94-45ba-9fc6-560c82782c54.SceneData.xml result=0
0m 08.62s: scene data: delete dir C:/Users/Logandog/Documents/DVDFab10/SceneData/34736900-fd94-45ba-9fc6-560c82782c54 result=0
0m 08.63s: Cinavia Version : 1.246.2.26
0m 09.58s: got max lba 22529055
0m 11.31s: got disc type 20
0m 11.31s: type Blu-ray BDMV
0m 11.31s: volume label BREAKING_BAD_S3_D2
0m 11.31s: DriveX msg: media open(false) sucess in driveX F.
0m 11.32s: DriveX msg: add media success in driveX F.
0m 11.32s: DriveX msg: send open media msg to thread for driveX F.
0m 11.32s: opening drive E
0m 11.32s: opened i/o
0m 11.33s: Source manager: open source flag:1,0,1,1,1
0m 11.34s: Source manager: add source id 0.
0m 11.35s: bd set region ?
0m 11.35s: Source open status
VD Yes, 2231-10-11
0m 11.35s: Source open status:BD Yes, 2231-10-11
0m 11.35s: internal path F:/BDMV/
0m 12.31s: aacs 1 bd+ 0
0m 12.53s: got bdmv
0m 12.54s: got agid 0
0m 12.60s: sent host cert chal
0m 12.60s: got drive cert chal
0m 12.60s: BEC 1
0m 12.60s: DRIVE_VENDOR 0x0080
0m 12.67s: got drive key
0m 14.06s: got host key signature
0m 14.06s: verified drive signature
0m 14.06s: verified host signature
0m 14.14s: sent host signature and key point
0m 14.14s: got bus key
0m 16.29s: got volume id
0m 16.29s: got volume id mac
0m 16.29s: volume id is correct
0m 16.29s: got vid
0m 16.30s: user cancelled
0m 16.30s: blu-ray 0000000000000000000000000000000000000000
0m 16.30s: ff error: 4
0m 16.30s: OpenSourceMedia global exception
0m 16.30s: Source manager: open failed, delete source id 0.
0m 16.31s: Source manager: open source flag:1,0,1,1,1
0m 24.07s: Source manager: open source flag:1,0,1,1,1
15m 50.37s: set folder F:/BDMV/ with type 2
15m 50.37s: opening folder F:/BDMV/
15m 50.39s: Source manager: add source id 1.
15m 50.41s: bd set region ?
15m 50.41s: Source open status
VD Yes, 2231-10-11
15m 50.41s: Source open status:BD Yes, 2231-10-11
15m 50.42s: opening drive F
15m 50.42s: opened i/o
15m 50.85s: got max lba 22529055
15m 52.11s: got disc type 20
15m 52.11s: internal path F:/BDMV/
15m 52.98s: aacs 1 bd+ 0
15m 53.20s: got bdmv
15m 53.20s: got agid 0
15m 53.26s: sent host cert chal
15m 53.26s: got drive cert chal
15m 53.26s: BEC 1
15m 53.26s: DRIVE_VENDOR 0x0080
15m 53.34s: got drive key
15m 53.34s: got host key signature
15m 53.34s: verified drive signature
15m 53.34s: verified host signature
15m 53.42s: sent host signature and key point
15m 53.42s: got bus key
15m 55.56s: got volume id
15m 55.56s: got volume id mac
15m 55.56s: volume id is correct
15m 55.56s: got vid
15m 55.77s: blu-ray 499A0034CFFFDFF8FE41D9CBE4FFA764C8FC9652
15m 56.37s: cert BEE=0x00 same
15m 56.73s: D 0AA0CC3F
15m 56.73s: selected region A
15m 56.73s: bd set region A
15m 59.03s: got vuk
15m 59.28s: got unit key 4
15m 59.52s: Get BluPathData and RRdata
15m 59.86s: StealthyClone with BluPath
16m 01.00s: got bdmv
16m 03.19s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 03.34s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 03.78s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 03.94s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 04.11s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 04.31s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 04.50s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 04.66s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 04.82s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 05.02s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 05.23s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 05.41s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 05.60s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 05.81s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 05.98s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 06.14s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 06.31s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 06.54s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 06.69s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 06.82s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 06.97s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 07.29s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 07.42s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 07.59s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 07.74s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 07.87s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 08.01s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 08.17s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
16m 08.99s: got extended bdinfo
16m 08.99s: opened blu-ray
16m 09.21s: TitleInfo : BD Parse Clone Title WARRING. title ID = 0
16m 09.21s: TitleInfo : BD Parse Clone Title WARRING. title ID = 1
16m 09.21s: TitleInfo : BD Parse Clone Title WARRING. title ID = 2
16m 09.21s: TitleInfo : BD Parse Clone Title WARRING. title ID = 3
16m 09.21s: TitleInfo : BD Parse Clone Title WARRING. title ID = 4
16m 09.21s: TitleInfo : BD Parse Clone Title WARRING. title ID = 5
16m 09.21s: TitleInfo : BD Parse Clone Title WARRING. title ID = 6
16m 09.21s: TitleInfo : BD Parse Clone Title WARRING. title ID = 7
16m 09.21s: TitleInfo : BD Parse Clone Title WARRING. title ID = 8
16m 09.21s: TitleInfo : BD Parse Clone Title WARRING. title ID = 9
16m 09.21s: TitleInfo : BD Parse Clone Title WARRING. title ID = 10
16m 09.21s: TitleInfo : BD Parse Clone Title WARRING. title ID = 11
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 12
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 13
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 14
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 15
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 16
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 17
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 18
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 19
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 20
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 21
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 22
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 23
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 24
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 25
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 26
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 27
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 28
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 29
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 30
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 31
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 32
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 33
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 34
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 35
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 36
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 37
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 38
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 39
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 40
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 41
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 42
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 43
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 44
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 45
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 46
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 47
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 48
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 49
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 50
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 51
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 52
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 53
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 54
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 55
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 56
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 57
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 58
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 59
16m 09.22s: TitleInfo : BD Parse Clone Title WARRING. title ID = 60
16m 11.11s: MoviePoster Log: Volume(BREAKING_BAD__SEASON_3__DISC_2), DiscID(BDD6AAA47A77032FE0011DBD4), Result((null))
16m 11.11s: Cinavia: no cinavia repair data.
16m 11.65s: Meta: the ownership is E_Meta_No_Owner.
16m 11.65s: Source manager: open successful.
16m 11.68s: Meta: editable flag is META_INFO_EDITABLE_FLAG_NOT_FOND
16m 15.22s: Work manager: create BD fulldisc work 0 with source 1 and uiinfo 0.
16m 15.38s: bd-fulldisk: FillWorkData not rmove audio
16m 15.39s: bd-fulldisk: FillWorkData not rmove audio
16m 16.03s: bd-fulldisk: FillWorkData not rmove audio
16m 16.39s: bd-fulldisk: FillWorkData not rmove audio
16m 18.38s: Source manager: select video files for open.
16m 18.38s: Source manager: open source flag:1,0,1,1,1
16m 32.74s: bd-fulldisk: FillWorkData not rmove audio
16m 32.77s: bd-fulldisk: FillWorkData not rmove audio
16m 42.07s: bd-fulldisk: FillWorkData not rmove audio
16m 42.26s: bd-fulldisk: FillWorkData not rmove audio
16m 42.47s: bd-fulldisk: FillWorkData not rmove audio
17m 27.88s: UILog: OnMsgToolbar_Start
17m 27.89s: UILog: Msg Start: ready start
17m 27.94s: UILog: Msg Start: start test run work
17m 27.94s: UILog: Msg Start: run work
17m 27.94s: UILog: Run current Work.
17m 28.50s: UILog: Begin work copy or converter.
17m 28.53s: Init BurnLog : file(C:/Users/Logandog/Documents/DVDFab10/Log/burn_internal.log)
17m 28.54s: UILog: start running at thread.
17m 28.55s: opening drive F
17m 28.56s: opened i/o
17m 28.56s: got media type 15
17m 29.02s: got max lba 22529055
17m 30.19s: got disc type 20
17m 30.19s: type Blu-ray BDMV
17m 30.19s: volume label BREAKING_BAD_S3_D2
17m 30.19s: UILog: return flag at start running at thread ok.
17m 30.21s: bd-fulldisk: FillWorkData not rmove audio
17m 30.25s: UILog:MsgWork:WorkStatus_Start
17m 30.25s: BD FullDisc watermark flag: 0
17m 30.25s: bd-fulldisk: RunTask 0 audios
------ process working ------
0m 00.13s: opening drive F
0m 00.14s: opened i/o
0m 00.14s: got media type 15
0m 00.51s: got max lba 22529055
0m 01.68s: got disc type 20
0m 01.68s: type Blu-ray BDMV
0m 01.68s: volume label BREAKING_BAD_S3_D2
0m 01.68s: bd set region A
0m 01.68s: internal path F:/BDMV/
0m 02.45s: aacs 1 bd+ 0
0m 02.65s: got bdmv
0m 02.66s: got agid 0
0m 02.72s: sent host cert chal
0m 02.72s: got drive cert chal
0m 02.72s: BEC 1
0m 02.72s: DRIVE_VENDOR 0x0080
0m 02.80s: got drive key
0m 03.91s: got host key signature
0m 03.91s: verified drive signature
0m 03.91s: verified host signature
0m 03.99s: sent host signature and key point
0m 03.99s: got bus key
0m 06.12s: got volume id
0m 06.12s: got volume id mac
0m 06.12s: volume id is correct
0m 06.12s: got vid
0m 06.37s: blu-ray 499A0034CFFFDFF8FE41D9CBE4FFA764C8FC9652
0m 06.96s: cert BEE=0x00 same
0m 07.32s: D 0AA0CC3F
0m 07.32s: selected region A
0m 07.32s: bd set region A
0m 09.65s: got vuk
0m 09.89s: got unit key 4
0m 10.11s: Get BluPathData and RRdata
0m 10.44s: StealthyClone with BluPath
0m 11.67s: got bdmv
0m 13.85s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 14.00s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 14.43s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 14.60s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 14.77s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 14.96s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 15.15s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 15.32s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 15.47s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 15.68s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 15.89s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 16.08s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 16.28s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 16.48s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 16.67s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 16.83s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 17.01s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 17.24s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 17.39s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 17.52s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 17.67s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 18.01s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 18.14s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 18.31s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 18.46s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 18.60s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 18.74s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 18.89s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 19.30s: got extended bdinfo
0m 19.30s: opened blu-ray
4m 17.12s: Blu-ray Copy: Full Disc
4m 17.12s: Source: F:/BDMV/
4m 17.12s: SourceSize: 43139 MB
4m 17.12s: RemoveHDAudio: 1
4m 17.12s: OutputSize: 23000 MB
4m 17.12s: OtherSize (CLPI, JAR, etc.): 211 MB
4m 17.12s: OutputDisc: BDMV
4m 17.12s: OutputTarget: BD25
4m 17.12s: OutputVideo: 1080p/i
4m 28.67s: Output group estimatedblock size
4m 28.67s: EstimatedBlocks: 12288, EstimatedMainVideoBlocks: 11595
4m 28.67s: EstimatedBlocks: 57723, EstimatedMainVideoBlocks: 57483
4m 28.67s: EstimatedBlocks: 63228, EstimatedMainVideoBlocks: 60228
4m 28.67s: EstimatedBlocks: 267930, EstimatedMainVideoBlocks: 263396
4m 28.67s: EstimatedBlocks: 568908, EstimatedMainVideoBlocks: 559273
4m 28.67s: EstimatedBlocks: 788223, EstimatedMainVideoBlocks: 774882
4m 28.67s: EstimatedBlocks: 3795188, EstimatedMainVideoBlocks: 3428639
4m 28.67s: EstimatedBlocks: 3813903, EstimatedMainVideoBlocks: 3436338
4m 28.67s: EstimatedBlocks: 3798750, EstimatedMainVideoBlocks: 3428956
4m 28.67s: EstimatedBlocks: 3803350, EstimatedMainVideoBlocks: 3428072
4m 28.67s: EstimatedBlocks: 5009349, EstimatedMainVideoBlocks: 4924411
4m 28.67s: to estimate the size of the group, index:0
4m 28.68s: RealOutputBlocks: 0, EstimatedBlocksCanNotBeCompressed: 1605567
4m 28.68s: info: create bdcopy config
4m 28.68s: info: recommand= 8248, Shrink support= 1, enable= 1, cuda_cap= 1 , cpu_count= 4
4m 28.68s: info: vdecode hevc= 0, h264= 1, vc1= 1, mpeg2= 1, vencode h264= 6, hevc= 0 , plat = 0
4m 28.68s: info: create bdcopy manager
4m 28.72s: info: enable bd copy(mode=1)
4m 28.72s: info: estimate copied other streams size(1 MB), estimate output video size(10 MB)
4m 28.72s: info: video encode mode(0), bitrate(5922), lr-encode(no)
4m 28.72s: info: video codec(2)
4m 28.72s: info: streams(4113.2,4352.1)
4m 28.72s: info: blu-ray copy begin (unit[elem[atomic[00230.m2ts]]])
4m 28.72s: CUDA GPU acceleration for Lightning-Shrink enabled
4m 28.72s: info: bitmap index = 1
4m 28.72s: info: h264_encode: encode param profile(2) level(41) bitrate(5921) crf(-1) interlace(0)
4m 29.43s: info: processing source(00230.m2ts)
4m 30.66s: info: bluray read data end
4m 32.88s: info: group(elem[atomic[00230.m2ts]]) playtime(14431 ms) source(24 MB) request(12 MB) real(11 MB) bitrate(5921 kbps)
4m 32.88s: info: delete cuda Lightning-Shrink = 346
4m 32.88s: compress finished: groups request(12 MB, 12 MB) real(11 MB) average_bitrate(5922 kbps)
4m 32.88s: to estimate the size of the group, index:1
4m 32.88s: RealOutputBlocks: 6078, EstimatedBlocksCanNotBeCompressed: 1604874
4m 32.88s: info: create bdcopy config
4m 32.88s: info: vdecode hevc= 0, h264= 1, vc1= 1, mpeg2= 1, vencode h264= 6, hevc= 0 , plat = 0
4m 32.88s: info: create bdcopy manager
4m 32.88s: info: enable bd copy(mode=1)
4m 32.88s: info: estimate copied other streams size(0 MB), estimate output video size(54 MB)
4m 32.88s: info: video encode mode(0), bitrate(7285), lr-encode(no)
4m 32.88s: info: video codec(2)
4m 32.89s: info: streams(4113.2)
4m 32.89s: info: blu-ray copy begin (unit[elem[atomic[00260.m2ts]]])
4m 32.89s: CUDA GPU acceleration for Lightning-Shrink enabled
4m 32.89s: info: bitmap index = 1
4m 32.89s: info: h264_encode: encode param profile(2) level(41) bitrate(7285) crf(-1) interlace(0)
4m 32.99s: info: processing source(00260.m2ts)
4m 39.03s: info: bluray read data end
4m 41.03s: info: group(elem[atomic[00260.m2ts]]) playtime(60060 ms) source(112 MB) request(55 MB) real(54 MB) bitrate(7285 kbps)
4m 41.03s: info: delete cuda Lightning-Shrink = 1440
4m 41.04s: compress finished: groups request(55 MB, 55 MB) real(54 MB) average_bitrate(7285 kbps)
4m 41.04s: to estimate the size of the group, index:2
4m 41.04s: RealOutputBlocks: 34170, EstimatedBlocksCanNotBeCompressed: 1604634
4m 41.04s: info: create bdcopy config
4m 41.04s: info: vdecode hevc= 0, h264= 1, vc1= 1, mpeg2= 1, vencode h264= 6, hevc= 0 , plat = 0
4m 41.04s: info: create bdcopy manager
4m 41.04s: info: enable bd copy(mode=1)
4m 41.04s: info: estimate copied other streams size(5 MB), estimate output video size(57 MB)
4m 41.04s: info: video encode mode(0), bitrate(2845), lr-encode(no)
4m 41.04s: info: video codec(2)
4m 41.04s: info: streams(4113.2,4352.1)
4m 41.04s: info: blu-ray copy begin (unit[elem[atomic[00296.m2ts],atomic[00298.m2ts],atomic[00297.m2ts]]])
4m 41.05s: info: ex process path= C:/Program Files (x86)/DVDFab 10/fabcore.exe
4m 42.13s: info: h264_encode: encode param profile(2) level(41) bitrate(2845) crf(-1) interlace(1)
4m 42.14s: info: processing source(00296.m2ts)
8m 58.67s: info: bluray read data end
8m 58.67s: info: processing source(00298.m2ts)
9m 03.67s: info: bluray read data end
9m 03.67s: info: processing source(00297.m2ts)
9m 58.99s: info: bluray read data end
10m 21.41s: info: group(elem[atomic[00296.m2ts],atomic[00298.m2ts],atomic[00297.m2ts]]) playtime(160860 ms) source(123 MB) request(63 MB) real(55 MB) bitrate(2845 kbps)
10m 21.43s: compress finished: groups request(63 MB, 63 MB) real(55 MB) average_bitrate(2845 kbps)
10m 22.44s: to estimate the size of the group, index:3
10m 22.44s: RealOutputBlocks: 62580, EstimatedBlocksCanNotBeCompressed: 1601634
10m 22.44s: info: create bdcopy config
10m 22.44s: info: vdecode hevc= 0, h264= 1, vc1= 1, mpeg2= 1, vencode h264= 6, hevc= 0 , plat = 0
10m 22.45s: info: create bdcopy manager
10m 22.45s: info: enable bd copy(mode=1)
10m 22.45s: info: estimate copied other streams size(8 MB), estimate output video size(251 MB)
10m 22.45s: info: video encode mode(0), bitrate(8291), lr-encode(no)
10m 22.45s: info: video codec(28)
10m 22.45s: info: streams(4113.2,4352.1)
10m 22.45s: info: blu-ray copy begin (unit[elem[atomic[00321.m2ts]]])
10m 22.45s: CUDA GPU acceleration for video decoding enabled
10m 22.50s: info: ex process path= C:/Program Files (x86)/DVDFab 10/fabcore.exe
10m 23.67s: info: h264_encode: encode param profile(2) level(41) bitrate(8291) crf(-1) interlace(1)
10m 23.68s: info: processing source(00321.m2ts)
34m 29.90s: UILog: OnMsgToolbar_Stop
16m 56.91s: info: filter:filter_video_decode
16m 56.91s: info: fifo:80c7c-filter_h264_ex-0-1,block:20
16m 56.91s: info: filter:filter_h264_ex
16m 56.91s: info: fifo:80c7c-filter_mux_mpeg-0-1,block:0
16m 56.91s: info: filter:filter_mux_mpeg
16m 56.91s: info: filter:bd_copy_demux
16m 56.91s: info: fifo:80c7c-filter_video_decode-0-1,block:124
16m 56.91s: info: fifo:80c7c-filter_mux_mpeg-1-2,block:188
16m 58.41s: info: group(elem[atomic[00321.m2ts]]) playtime(243109 ms) source(523 MB) request(260 MB) real(153 MB) bitrate(8291 kbps)
16m 58.43s: compress finished: groups request(260 MB, 260 MB) real(153 MB) average_bitrate(8291 kbps)
34m 35.25s: UILog: MsgWork:current work finish: 4
34m 35.27s: Source manager: open source flag:1,1,1,1,1
34m 38.94s: bd-fulldisk: FillWorkData not rmove audio
34m 38.95s: bd-fulldisk: FillWorkData not rmove audio
34m 39.18s: bd-fulldisk: FillWorkData not rmove audio
34m 39.39s: bd-fulldisk: FillWorkData not rmove audio
34m 39.41s: bd-fulldisk: FillWorkData not rmove audio
34m 39.46s: bd-fulldisk: FillWorkData not rmove audio
34m 39.69s: bd-fulldisk: FillWorkData not rmove audio
34m 39.71s: Source manager: open source flag:1,0,1,1,1
34m 39.98s: bd-fulldisk: FillWorkData not rmove audio
35m 09.34s: UILog: OnMsgToolbar_Start
35m 09.35s: UILog: Msg Start: ready start
35m 09.38s: UILog: Msg Start: start test run work
35m 09.38s: UILog: Msg Start: run work
35m 09.38s: UILog: Run current Work.
35m 10.16s: UILog: Begin work copy or converter.
35m 10.18s: UILog: start running at thread.
35m 10.18s: opening drive F
35m 10.19s: opened i/o
35m 10.19s: got media type 15
35m 10.80s: got max lba 22529055
35m 11.96s: got disc type 20
35m 11.96s: type Blu-ray BDMV
35m 11.96s: volume label BREAKING_BAD_S3_D2
35m 11.96s: UILog: return flag at start running at thread ok.
35m 11.97s: bd-fulldisk: FillWorkData not rmove audio
35m 12.01s: BD FullDisc watermark flag: 0
35m 12.01s: UILog:MsgWork:WorkStatus_Start
35m 12.01s: bd-fulldisk: RunTask 0 audios
0m 00.15s: opening drive F
0m 00.15s: opened i/o
0m 00.15s: got media type 15
0m 00.63s: got max lba 22529055
0m 01.70s: got disc type 20
0m 01.70s: type Blu-ray BDMV
0m 01.70s: volume label BREAKING_BAD_S3_D2
0m 01.70s: bd set region A
0m 01.71s: internal path F:/BDMV/
0m 02.48s: aacs 1 bd+ 0
0m 02.84s: got bdmv
0m 02.86s: got agid 0
0m 02.92s: sent host cert chal
0m 02.92s: got drive cert chal
0m 02.92s: BEC 1
0m 02.92s: DRIVE_VENDOR 0x0080
0m 02.99s: got drive key
0m 04.16s: got host key signature
0m 04.16s: verified drive signature
0m 04.16s: verified host signature
0m 04.24s: sent host signature and key point
0m 04.24s: got bus key
0m 06.41s: got volume id
0m 06.41s: got volume id mac
0m 06.41s: volume id is correct
0m 06.42s: got vid
0m 06.66s: blu-ray 499A0034CFFFDFF8FE41D9CBE4FFA764C8FC9652
0m 07.63s: cert BEE=0x00 same
0m 08.00s: D 0AA0CC3F
0m 08.00s: selected region A
0m 08.00s: bd set region A
0m 10.47s: got vuk
0m 10.71s: got unit key 4
0m 10.93s: Get BluPathData and RRdata
0m 11.30s: StealthyClone with BluPath
0m 12.61s: got bdmv
0m 14.81s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 14.93s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 15.38s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 15.54s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 15.71s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 16.07s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 16.23s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 16.39s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 16.58s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 16.78s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 16.96s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 17.14s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 17.36s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 17.53s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 17.69s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 17.86s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 18.10s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 18.26s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 18.40s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 18.55s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 18.88s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 19.04s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 19.21s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 19.35s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 19.49s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 19.63s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 19.79s: stream(27,3,6)/clip(27,3,4) infos are not the same, using clip info to regulate it.
0m 20.19s: got extended bdinfo
0m 20.19s: opened blu-ray
4m 14.56s: Blu-ray Copy: Full Disc
4m 14.56s: Source: F:/BDMV/
4m 14.56s: SourceSize: 43139 MB
4m 14.56s: RemoveHDAudio: 1
4m 14.56s: OutputSize: 23000 MB
4m 14.56s: OtherSize (CLPI, JAR, etc.): 211 MB
4m 14.56s: OutputDisc: BDMV
4m 14.56s: OutputTarget: BD25
4m 14.56s: OutputVideo: 1080p/i
4m 26.77s: Output group estimatedblock size
4m 26.77s: EstimatedBlocks: 12288, EstimatedMainVideoBlocks: 11595
4m 26.77s: EstimatedBlocks: 57723, EstimatedMainVideoBlocks: 57483
4m 26.77s: EstimatedBlocks: 63228, EstimatedMainVideoBlocks: 60228
4m 26.77s: EstimatedBlocks: 267930, EstimatedMainVideoBlocks: 263396
4m 26.77s: EstimatedBlocks: 568908, EstimatedMainVideoBlocks: 559273
4m 26.77s: EstimatedBlocks: 788223, EstimatedMainVideoBlocks: 774882
4m 26.77s: EstimatedBlocks: 3795188, EstimatedMainVideoBlocks: 3428639
4m 26.77s: EstimatedBlocks: 3813903, EstimatedMainVideoBlocks: 3436338
4m 26.77s: EstimatedBlocks: 3798750, EstimatedMainVideoBlocks: 3428956
4m 26.77s: EstimatedBlocks: 3803350, EstimatedMainVideoBlocks: 3428072
4m 26.77s: EstimatedBlocks: 5009349, EstimatedMainVideoBlocks: 4924411
4m 26.77s: to estimate the size of the group, index:0
4m 26.77s: RealOutputBlocks: 0, EstimatedBlocksCanNotBeCompressed: 1605567
4m 26.77s: info: create bdcopy config
4m 26.77s: info: recommand= 8248, Shrink support= 1, enable= 1, cuda_cap= 1 , cpu_count= 4
4m 26.77s: info: vdecode hevc= 0, h264= 0, vc1= 0, mpeg2= 0, vencode h264= 0, hevc= 0 , plat = 0
4m 26.77s: info: create bdcopy manager
4m 26.98s: info: enable bd copy(mode=0)
4m 26.98s: info: estimate copied other streams size(1 MB), estimate output video size(10 MB)
4m 26.98s: info: video encode mode(0), bitrate(5922), lr-encode(no)
4m 26.98s: info: video codec(2)
4m 26.98s: info: streams(4113.2)
4m 26.98s: info: blu-ray copy begin (unit[elem[atomic[00230.m2ts]]])
4m 26.99s: info: ex process path= C:/Program Files (x86)/DVDFab 10/fabcore.exe
4m 28.05s: info: h264_encode: encode param profile(2) level(41) bitrate(5921) crf(-1) interlace(0)
4m 28.06s: info: processing source(00230.m2ts)
4m 35.10s: info: bluray read data end
4m 47.87s: info: group(elem[atomic[00230.m2ts]]) playtime(14431 ms) source(24 MB) request(12 MB) real(9 MB) bitrate(5921 kbps)
4m 47.88s: compress finished: groups request(12 MB, 12 MB) real(9 MB) average_bitrate(5922 kbps)
4m 48.89s: to estimate the size of the group, index:1
4m 48.89s: RealOutputBlocks: 4818, EstimatedBlocksCanNotBeCompressed: 1604874
4m 48.89s: info: create bdcopy config
4m 48.89s: info: vdecode hevc= 0, h264= 0, vc1= 0, mpeg2= 0, vencode h264= 0, hevc= 0 , plat = 0
4m 48.89s: info: create bdcopy manager
4m 48.89s: info: enable bd copy(mode=0)
4m 48.90s: info: estimate copied other streams size(0 MB), estimate output video size(54 MB)
4m 48.90s: info: video encode mode(0), bitrate(7285), lr-encode(no)
4m 48.90s: info: video codec(2)
4m 48.90s: info: streams(4113.2)
4m 48.90s: info: blu-ray copy begin (unit[elem[atomic[00260.m2ts]]])
4m 48.90s: info: ex process path= C:/Program Files (x86)/DVDFab 10/fabcore.exe
4m 49.94s: info: h264_encode: encode param profile(2) level(41) bitrate(7285) crf(-1) interlace(0)
4m 49.95s: info: processing source(00260.m2ts)
5m 42.60s: info: bluray read data end
5m 50.48s: info: group(elem[atomic[00260.m2ts]]) playtime(60060 ms) source(112 MB) request(55 MB) real(33 MB) bitrate(7285 kbps)
5m 50.49s: compress finished: groups request(55 MB, 55 MB) real(33 MB) average_bitrate(7285 kbps)
5m 51.51s: to estimate the size of the group, index:2
5m 51.51s: RealOutputBlocks: 22041, EstimatedBlocksCanNotBeCompressed: 1604634
5m 51.51s: info: create bdcopy config
5m 51.51s: info: vdecode hevc= 0, h264= 0, vc1= 0, mpeg2= 0, vencode h264= 0, hevc= 0 , plat = 0
5m 51.51s: info: create bdcopy manager
5m 51.51s: info: enable bd copy(mode=0)
5m 51.51s: info: estimate copied other streams size(5 MB), estimate output video size(57 MB)
5m 51.52s: info: video encode mode(0), bitrate(2845), lr-encode(no)
5m 51.52s: info: video codec(2)
5m 51.52s: info: streams(4113.2)
5m 51.52s: info: blu-ray copy begin (unit[elem[atomic[00296.m2ts],atomic[00298.m2ts],atomic[00297.m2ts]]])
5m 51.52s: info: ex process path= C:/Program Files (x86)/DVDFab 10/fabcore.exe
5m 52.57s: info: h264_encode: encode param profile(2) level(41) bitrate(2845) crf(-1) interlace(1)
5m 52.58s: info: processing source(00296.m2ts)
42m 04.19s: UILog: OnMsgToolbar_Stop
6m 48.30s: info: filter:filter_video_decode
6m 48.30s: info: fifo:8d41c-filter_vfilter_filters-1-1,block:20
6m 48.30s: info: filter:filter_h264_ex
6m 48.30s: info: fifo:8d41c-bd_remaster_mux-1-1,block:0
6m 48.30s: info: filter:filter_vfilter_filters
6m 48.30s: info: fifo:8d41c-filter_h264_ex-1-1,block:20
6m 48.30s: info: filter:bd_remaster_demux
6m 48.31s: info: fifo:8d41c-bd_remaster_mux-0-0,block:86
6m 48.31s: info: fifo:8d41c-filter_video_decode-1-1,block:335
6m 48.31s: info: fifo:8d41c-bd_remaster_mux-2-3,block:400
6m 48.31s: info: filter:bd_remaster_mux
6m 49.36s: info: group(elem[atomic[00296.m2ts],atomic[00298.m2ts],atomic[00297.m2ts]]) playtime(160860 ms) source(123 MB) request(63 MB) real(12 MB) bitrate(2845 kbps)
6m 49.39s: compress finished: groups request(63 MB, 63 MB) real(12 MB) average_bitrate(2845 kbps)
42m 06.00s: UILog: MsgWork:current work finish: 4
42m 06.01s: Source manager: open source flag:1,1,1,1,1
42m 08.68s: bd-fulldisk: FillWorkData not rmove audio
42m 08.80s: bd-fulldisk: FillWorkData not rmove audio
42m 09.00s: bd-fulldisk: FillWorkData not rmove audio
42m 09.20s: bd-fulldisk: FillWorkData not rmove audio
42m 09.24s: bd-fulldisk: FillWorkData not rmove audio
42m 09.26s: Source manager: open source flag:1,0,1,1,1
42m 09.71s: bd-fulldisk: FillWorkData not rmove audio
0m 12.53s: got bdmv
0m 12.60s: BEC 1
0m 16.29s: got vid
15m 53.26s: BEC 1
15m 55.56s: got vid
15m 59.03s: got vuk
0m 02.65s: got bdmv
0m 02.72s: BEC 1
0m 06.12s: got vid
0m 09.65s: got vuk
0m 11.67s: got bdmv
0m 02.84s: got bdmv
0m 02.92s: BEC 1
0m 06.42s: got vid
0m 10.47s: got vuk
0m 12.61s: got bdmv
