Converting PAL Region 2 to NTSC Region 1
    Other Converting PAL Region 2 to NTSC Region 1
    I purchased a set of 3 Steven Seagal movies on DVD. The online product information didn't say that the DVDs were PAL format with a region code of 2, so they wouldn't work on my Blu-ray/DVD player. I decided to use DVDFab Copy in Full Disc mode to convert the original PAL Region 2 DVD to an NTSC DVD playable in all regions. However, when I tried playing my newly created copy, it was still a PAL DVD with Region Code 2. What did I do wrong or fail to do?
    DVDFab won't convert Pal to NTSC it will and probably did remove the region code but your player just won't play PAL format.
