Display Problem
    GUI Display Problem
    The latest version of DVDFab (DVDFab 10.0.3.4) does not scale properly to the screen. The last version did. I have a high resolution screen (2560x1440) and the program display is huge- so large, it can't be used. The screen display (Windows) is set to 200%. When I set it to 100% then DVDFab shows at the right size. However, now everything else is so tiny on the desktop that it hardly can be read. For your info the intel graphics chip is set to scale the display. Something changed on the latest update to DVDFab.
    Try the newest Fab 1035
    https://www.dvdfab.cn/dvd-blu-ray-cinavia-removal.htm
    I use 150% with no problem give it a try.
    I did have a Hugh problem with scaling in the past it happened when the box Fab displays in when the app. was run was shrunk in size with the arrows in windows to expand and contract the box size.When adjusted to make the box smaller so I can see some of the other programs on the windows desk top.Keep the box windows displays Fab in the same size after downloading the program doing a clean install restored it.
