Updating v9 to v10
    Other Updating v9 to v10
    I have DVDFab v9 (9219) circa 2013
    The latest update is v10 (9322)
    The update screen shows this message
    The All-New DVDFab 10 has been released for quite a while, and it’s totally free to the existing paid users with unexpired licenses of the previous generation. By creating a separate installation folder, DVDFab 10 can co-exist with DVDFab 9 on your computer.
    Note that the version 9.3.2.2 listed above will get you DVDFab 10 in fact, as there is known problem detecting version 10 from version 9.
    More Info: http://www.dvdfab.cn/dvdfab10.htm
    I have lifetime registration for Ripper and Copy
    Q1: Do I download v10 and install as a new install and not an update on top of v9 ?
    Q2: Do I need to keep v9 ? It was/is very hard (a lot of thrashing) on DVD drive. I have had to replace the DVD drive several times.
    . . . The Lite-On DVD drive is 3 drives ago.
    Q3: Do I use my original registration code to activate v10 ?
    Thank you
    SPECS:
    DVD-Copy ... lifetime
    DVD-Ripper ... lifetime
    Win7 Home Premium 64bit
    SSD for C:\
    HDD (internal) for D:\
    Lite-On CD/DVD RW: iHAS324-07 WU
    Q1/Q2 V10 installs in a separate folder and is not an update to V9 so you can keep V9 or not your choice.
    Q3 No you will need to go to the members site and create an account using the email address you used when you purchased DVDFab and a password of your choice. Activate V10 with your account info.
