A while back I posted an issue I was having with a trying to clone burn a specific dvd.I notice today that the log says (Failed to burn due to oversized source files.) How to I fix this?
Need Help With Issue with DVDfab
Clone is a bit for bit copy so the blank media has to be the same as the original. A commercially released DVD typically won't clone to single layer (4.7GB) media.How to post the internal log
Okay just sayin'How to post the internal log
Originally posted by october262 View PostPlease post the dvdfab internal log files
As well as the burn log files.Attached Files
I thought it might have something to do with cloning an iso image so I tried one and it seemed to work and play fine burning with ImgBurn. I made the iso with Fab a while back so if you are using something else or downloading them all bets are off.How to post the internal log
Originally posted by 90312 View PostI thought it might have something to do with cloning an iso image so I tried one and it seemed to work and play fine burning with ImgBurn. I made the iso with Fab a while back so if you are using something else or downloading them all bets are off.
