DVD Burning
    DVD Burning
    I am having problem burning a copy of a DVD I got at Dolphin Discover in Mexico. It is burned on a DVD-RW Verbatim. It has two files on the Disk one is blank and the other one is the actual movie. When I record the DVD it only copies the blank file. I tried to use the customize or split option but no files show up. Please help me figure out how to copy this disk.
    Thank you in advance.
    If it is on a DVD-RW, it will have no copy protection and all you need to do is use your normal DVD burning software too do this.
    No need to use Fab at all. In fact Fab can get confused by disks such as these as it is most probaly not fully compliant with DVD standards.
      what type of file is on the disc?
      .iso? .img? .vob? ...etc
