I just purshased DVD to DVD and DVD to Mobile. All of this is because I wanted to put away all DVD's in storage, and save all movies in Window Home Server (2 Harddrives total 2 TB) sitting in basement.
Reason for me to buy this software are:
1. Easy to use
2. allow me to remote access to Home Server and run this software
3. fast encoding
4. Subtitle working in MP4 format.
I also used Handbrake software because it is free and subtitle works for me. But it is painful slow with high end power computer. This software give superior quality video and sounds in MP4 format and are around 1.2gb per DVD's.
I wanted to use DVDfab tools over Handbrake, because it run better with queue movies, and it run much faster.
The downhill is the quality are pretty bad on DVDfab. Even I have set the MP4 as H.264, and the bit rate is set to 1024. I have been playing around with MP4 formats and nothing come out with good quality with 50' samsung TV and Playstation 3 connected to my server.
Any suggestion or advice will be appreicated.
1. Easy to use
3. fast encoding
