32bit vs 64bit program
    I have the 32bit DVDFab. If I don't copy Bluray or 4K would the 64bit still be better? If it's better how do I replace mine? Do I delete my DVDFab and then install the 64bit DVDFab, or do I just install it? I would appreciate any advice.
    Ernie
    Just install it, both will run side by side.
      I just found the new DVDFab 10 (64). I already downloaded the new DVDFab 10, which downloaded perfectly as usual. I opened the DVDFab 10 (64) on my desktop and went to the Forum to download the new (64) but the quick install picture came up but never installed it. I'm not sure what I'm doing wrong. Any help would be appreciated.
      Thank you
        You do have a 64 bit OS don't you?
          Yes I do. Right now I have DVDFab 10.0.8.4 and DVDFab 10.0.8.1 (64)
            I have the problem taken care of. When I downloaded DVDFab 10.0.8.4 (x64) it would not upgrade my 10.0.8.1 (x64). I then started searching for the download and found it in DOWNLOADS. I then double clicked it and it upgraded my 10.0.8.1 to 10.0.8.4.
