Cannot seem to do anything. Are the servers down?
Servers Down??
Originally posted by tmagz52 View PostI am having the same issues. Cant connect or load a disc. Was working fine a few hours ago, including cinavia removal.
Did you authorize your pc recently? I did today and seemed alright for one copy, then the next time I opened the program, would not connect.
It should recovered now, please try again.DVDFab is the all-in-one software package for copying Blu-ray/DVD and converting video file.
http://www.dvdfab.cn
BTW, the servers being down with no notification caused me to accidentally delete about 5 hours of work while trying to remove the temp directory attempting to "fix" something that wasn't fixable. Not a happy camper about that. Maybe you should put some sort of notice in the software about not being able to connect to the required resources. Just a thought.Last edited by rlp122; 02-04-2018, 01:07 AM.
