I am having a problem with v10, but x32 and x64 bit versions. In v9, the Blu-Ray Drive reads the disc just fine and loads it into DVDFab. However, on v10, it will not pull up the movies on the disc so I can copy them. I really want to use the x64 v10 to speed up the process. I made sure my drive was check marked in Drives within the settings. Anyone else have this issue or know how to fix it?
Blu-Ray discs not showing up on v10
Please post the DVDFab internal log file first, thanks!
WilsonPlease post your logs the default location is:
