I have lots of TV shows that I wanted to try to back up in bluray. Since BD50s are still quite expensive, I tried splitting these up so each episode would fit onto a dual layer DVD.
The file on the hard drive plays fine, but when you burn the image to the BD-9 the sound goes in and out for the first few minutes. I burned multiple discs and all have the same problem. Burning at the slowest speed for the Verbatim DVD+R DL, which is 2.4x. Tried ImgBurn, VSO, and Nero. All get the same problem. The sound also goes out in the same exact place on all of the copies.
Any Ideas?
Any Ideas?
- Benjamin Franklin 1706-1790
